Help Need Help With Meep
bitsy1980
My stepdaughter got a Meep for Christmas! Her mom sent the info we need to change and add apps. I finally got it to get off times up and now that I tried to add a google app it says android.process.acore has stopped... they should have got a Kindle..... I can work it now:(
Glad to have you join us here at Android Forums, Bitsy.
It looks like olbriar above me there has you pointed in the right direction, so I hope the good folks over in the MEEP forum can answer any questions you have on it.
If there's some other way we can assist you, just let us know - we'd be happy to help. :)
- eyebeam
Hey there and welcome to Android Forums. :)
Hopefully the folks in the MEEP forums can give you a hand with your problem (echo? :p)
If we can assist you with anything, don't hesitate to ask. :)
DS
Hi! I'm here from Meep :) The message android.process.acore has stopped as well as 'times up' usually can be corrected by our latest firmware update (we're now up to version 2.0 as of Feb 5th). Also, make sure your Meep is registered and that you have a strong wifi connection when doing tasks that involve wifi. In your portal settings, it's best to run with Low security as well. If we can be of any more help, one of the best ways to reach us is on Facebook: https://www.facebook.com/MeepTablet.US
