Root Need help with rom flashing- semi brick
cadrion
Hi guys....need a bit of help here. Here's what I did- used odin to slash back to official DI18. Used 1 click 2.5.5 to root, then copied the bonsai4all_leafless_4.0.0.zip to the sd. Got into clockwork mod and flashed the zip from sd, now it's stuck at the Samsung screen...What did i do wrong? did I even have to root it to ru the bonsai rom? Thanks.
Odin back to stock. Root with CWM3 (Ext4) not with CW2. Update your modem to EC05 and flash the ROM (be sure to do the 3 wipes).
I appreciate the quick reply....I've seen "the three wipes" before, but am not sure what that is...I'm guessing cache, data and dalvik data?
