Root Need help with "rooted" DroidX
KristiC
My dad gave me his "rooted" DroidX and I'm not sure how to go about updating the OS.
System: Version.2.3.340.MB810.Verizon.en.US
Model: DROIDX
Android: 2.2.1
Baseband: BP_C_01.09.07P
Kernel: 2.6.32.9-g55626e1 w30471@il93lnxdroid08 #1
Build: vzw
ERI: 5
PRL: 52280
When I turn the phone on, it boots to clockworkmod recovery v2.5.0.6 and I have to press the camera shutter button to continue booting the phone. My dad can't remember what he did to "root" the phone.
From reading/research, I'd like to run a mostly stock rom minus the bloatware (not sure which rom is good/best), otherwise plain gingerbread would be fine. I'm not sure where to start since I don't really know what he did to "root" the phone.
Oh, and even after charging the phone overnight, it only shows 80% charged. Not sure what that's all about.
Thanks!!!
well bud what we need to know is if you are on a rom right now, and if you arent but just rooted, you need to just perform a software update. and once it is done you will no longer be rooted, and you will be on stock gingerbread, from there you can reroot, and find you the rom of your choice in the rom/theme list, liberty, and apex are the best.
Hey i was wondering if you could help me with my problem i have a Droid X flashed to cricket i did the last update about a month or 2 ago and lost root System Version: 4.5.605.MB810.Verizon.en.US
Model: Droid X
Android Version: 2.3.3
Baseband Version: Bp_C_01.09.13p
Kernel Version: 2.6.32.9-g34b306d bmvq37@zin22lnxdroid28#1
Build Number: 4.5.1_57_DX5-35
ERI Version: 5
PRL Version: 42900
I've been trying to root my phone but i just cant figure out how please help if you can.... thanks
about phone will say something about apex being in it, but if you have apex installed thats a good start, what you need to do, is since your on a rom, you cannot do the update because his rom stops updates from happening, you need to sbf your phone to .602 gb
http://androidforums.com/droid-x-al...oot-process-updated-9-9-11-a.html#post2928345
follow those instructions and you will be A-OK
