Root Need help with rooting
cloudmesa
Phone SE Xperia X8
Model :E16I
I followed the instructions for SuperOneClick rooting software, and done the following steps
- download and unzip SuperOneClickv1.9.1-ShortFuse to PC Desktop
- connect Xperia X8 to PC (Do not mount)
- on your phone <goto><setting><applications> select <unknown sources>
- on your phone <goto><settings><applications><development> select <usb debugging>
- Launch SuperOneClick -> click <Root>
NOTE:
If SuperOneClick is running but hangs mid-process you need to install .NET Framework v2.0 or above. DO NOT ASSUME you are running Windows 7 it has .NET Framework installed.
I have .Net Framework v4.0, but it still hands mid-process, what should I do?
Phone SE Xperia X8
Model :E16I
I followed the instructions for SuperOneClick rooting software, and done the following steps... [edited]
[/COLOR][/B]I have .Net Framework v4.0, but it still hands mid-process, what should I do?
Hi,
download new SuperOneClick v2.3.3 and try again.
cheers :)
gabe
