Dsanity Newbie Aug 24, 2013 #1 I try to overwrite the file from the decepticon to the batman one and it says can't overwrite file is read only...NEED HELP! Edit: Also the Google play takes way to long to download stuff & i'm on a wifi connection..
mario0318 Well-Known Member Sep 20, 2013 #2 If you're using Root Explorer to replace the file, make sure you first set it off Read-Only mode then try replacing the file again.
