Root Need help with usb driver install
sleekmr3
Hi everyone.
This is as far as I have gotten so far.
So I followed the walkthrough for the usb driver install.
this link:
public:windows_hboot_driver_install [RootWiki]
the problem is when I go into device manager I couldn't find android 1.0 listed.
instead what I found was this.
See where it is highlighted "android bootloader interface" instead mine was labeled something different"android abd interface" (abd, and, anb or something similar i forget exactly)
what i did was I right clicked it and did the driver software look up and installed it. It installed like the instructions stated and now it's labeled correctly as "android bootloader interface"
my questions is since i didn't do via android 1.0 like the instructions said did I do it wrong?
so when I run reflash the unrevoke doesn't notice my device. It says plug in device and enable usb debugging.
I use pdanet so usb debugging is already on. Do I need to uncheck usb debugging and check it back on?
Why can't unrevoke see my phone?
Hi everyone.
this link:
If it says "android bootloader interface" then the drivers should be installed correctly. When I rooted mine it said 1.5, then after I updated the drivers "android bootloader interface".
I would try it without pdanet, make sure usb debugging is enabled and when you plug your phone in make sure to select "Disk Drive".
thanks. i will try that when I get home.
