Root Need help with WiFi Tethering
Sparkz
I am using a LG Optimus Slider, Gelato ROM, Gingerkernel, rooted for Virgin Mobile. I have been using an app called Barnacle WiFi Tether for sharing my 3G connection, however, I recently got a 3DS and it isn't working. I have looked up why this is, and to my knowledge, it is because Barnacle creates an ad-hoc network, which the 3DS isn't compatible with. Does anyone know a solution to this problem? Thanks
The solution is called a wifi router. Connecting one to an Android cellphone (to use the cellphone's internet connection) would be a bit of a trick.
