Even better - it could be masking itself in the autoexec.bat . ,cmd (if present), win.ini (if present) and a few other places as well. Registry is first place I'd look for, but sometimes the old ways work best b/c many modern system cleaners and overhaulers forget to look in the old places anymore...
Startup folder in Programs is another good place too look.
But all of these can be checked by WinPatrol![]()
I don't care what anyone says, the best way to get rid of all Windows issues is at the command prompt type in "Format C:".
What I've always thought would be a good idea for computers is a diagnostic port like cars (OBDII) where you can plug in a tablet or a laptop and run a complete diagnostic test/repair on a system that's acting weird. And by complete I mean HD tests, malware scans, hardware configuration. I'm sure something like that would take forever to implement and would probably thin out a lot of IT positions, but I've always thought it would be nice to have a comprehensive tool that any IT professional can just perform complete system scans via a cable.
Nah, the best fix is to install Gentoo FTW!
The fewer orphoned objects there are, the easier it is for me when I'm looking for other keys. Only slightly perhaps but nevertheless
That aside, though, a user of your expertise I have no qualms about using a reg cleaner. it's the novice users who get their info from a friend (who also happens to be another novice user) that keep me in business....
For me it's like some peoples' reaction to bloatware. It's for the most part benign and harmless except for the annoying updates, but I'd just rather not have it there. Yes computers are much more evolved and can run mostly without issue, but why do you want a registry entry that originated via some malware installation? Different strokes for different folks. I'd personally rather have a clean registry for my own peace of mind. It's like changing the oil on a car at recommended intervals or a few thousand miles later. People can argue either position until they're blue in the face. it all comes down to what the driver/enduser is most comfortable with.
This is strictly a startup issue. She's not launching IE, some process is. Nothing is proxied. After exiting the erroneous window (with the address bar conveniently hidden), everything works fine.
I have never been bothered. I look through registries several times a week and never even look to see if the keys I'm looking at are being referenced or not. It's completely irrelevant.
I'm the same way. You leave the orphaned keys alone and nothing will happen. You start trying to remove stuff and you're much more likely to make things worse as there is no way in the world to make things better. Registry cleaners are snake oil. The people who use them break their computers sometimes beyond repair which does make more work for me and keeps me in business. I hate cleaning up stupidity is all.
The registry key is benign. Removing it is the equivalent of having risky elective surgery. There's no justification for it. You could use my computer all day and have no idea if there were orphaned keys or malware related keys.
Yep, d
PS - Can't believe I didn't think to clear out temp.
it's beside the point though - we have various tools, but novice users aren't savvy enough to use them - and yet I see all over the Internet advice on what tools to use, how to fix things yourself, etc. etc. ad nauseum.
That's what really gets my goat (pun intended).
MSCONFIG checks the startup folder.
As I think about it more, it's probably a service that's running that's starting it. I'd bet if he went into MSCONFIG and disabled all non-Microsoft services it would fix the problem. It would break a ton of stuff no doubt, but it would be simple enough to look through the list of services and re-enable the ones you wanted/needed.
If it's a service, then it's masquerading as a Microsoft service and not being caught on scan.
I've been though startup with System Configuration Info and diagnostics, as mentioned.
And with Windows Defender.
Only by eventually disabling everything did this stop, but I haven't found the source.
Appreciate it! I know to diagnose services, that's why I was looking for a remote access approach - plus any other stones to overturn that I've been missing.
I rather not work by using exhaustive search if I can help it.
Cleaning up stupidity can be fun, though. Especially when I get to say "if you had come to me before trying all of this yourself, we could have saved it - now, I gotta format...."
Yeah, it's called Bart's PE and / or Ultimate Boot CD....
The problem with a plug in is the same as with these - they are only effective if the plug-in receptacle is actually functioning (and with these, you need either a working CD/DVD/BD ROM, or else a working USB, depending upon implementation). The good thing is that we do have test benches and the like to be able to test hardware - I try to keep spare parts handy so I can test things, but some things I cannot - for example, I have a Core i7 965 EE CPU - and the only mobo that will run that is the mobo it is in now. Same with the DDR3 RAM I have.
The HDs, Optical drives, etc. I can test by using another system - and I always have 1 spare optical (although it is IDE, and this mobo has no IDE, but I have a second spare optical that is SATA) and multiple ways to get USB working so long as the mobo's south bridge is not hosed.
Wouldn't be exhaustive really. There are some that you know are good services. You can select them all at once and kick them off. If you have no issues, then you can move on to the more suspicious ones.
Use Join.me. It's the easiest remote access tool I know. Mom clicks one link on the home page, runs a small program and gives you a 9 digit number. You type it in and you can see her screen.
That's called exhaustive search. You search until the mystery is found or the list is exhausted. Opposite of a causal search.
Appreciate the tip on Join.me - I'll check that out as well.![]()
Did you happen to run MBAM? If not I'd recommend it - b/c looking at this post XP AntiVirus 2011 - what a PITA - Malwarebytes Forum this thing is pretty well integrated into the system. Finding the correct file sis gonna take you a while if you don't know what you're looking for, even if you have a general idea where to look - that ST5.tmp file? lol - a visual inspection would have let that fly right past my radar....
Doesn't seem exhaustive to me. Would take less than 30 mins in my mind. I'm used to hunting down computer problems that take 4-5 times as long easily.
