Help need help
Hello, my samsung spica is having a weird problem, that without touching the screen or any keys, multiple applications are opening, even some times calls also going and while any incoming call comes without pressing any keys it is getting answered, all options are disable like auto answer, background data download disabled. please anyone help me to solve this problem, as i was unable to use the phone in this condition. p for charging,
pls help to sovle this problem,
Android automatically loads apps in the background in anticipation of you requiring them. The idea being the app will load faster. You have free RAM so Android is trying to help you. However, it may not necessarily have got it right in earlier versions. Even though Android is based on Linux, which is a pretty robust operating system.
To help you, lets start at the beginning..
What version of Android are you running? What is your BaseBand No?
From your phone.
Menu
Settings
About Phone.
BaseBand No?
OK that's an early Asian Firmare from March this year. Things didn't really start to work well on Android until JD1 was released, which was in April.
My first suggestion would be to reboot the phone, and see how it goes.
Next install an app called TasKiller from Market. Set it up to AutoKill apps when in sleep mode, but ignore those apps you do wish to run. Like your Home App.
It also might be worth considering updating to a later firmware, although that may have to be a European version.
Put your phone on a desk. Step well back and stare long and hard at it.
DO NOT BE TEMPTED TO TOUCH IT.
When the screen goes blank...
It's in sleep mode.
More commonly know as standby.
ok :)
i have under big problem my phone allwase frezzing do you no sumthing about this?
(i can not downloading the app TasKiller) :confused:
Or maybe give me change all the phone's software
I live in Israel Do you know the software version will solve all these problems??
Thanks
Try a full hardware reset. harsh I know, but has been know to work.
I can give you a link to download TasKiller (as it's free). You can copy this to your SD card and install it from there..
Lemme know if you want it.
ok
u can send me a link but..Or maybe give me change all the phone's software
Thanks
TasKiller App here..
TasKiller App
Copy it to your SD card.
on your phone, enable Unknown Sources
Menu
Settings
Applications
Unknown Sources [x] Enable it,
Browse to SD card and install TasKiller app.
Thanks
More than likely. You just need to backup your important data, including your providers APN (Access Point Names) settings.
Menu
Settings
Wireless & Networks
Mobile Networks
Access Point Names
Your Provider
Take a note of these settings
