need help.
samchock
y is my phone storage keep on reduce although i never install any application?and how to change application storage from phone to sd card?can any1 here help me?thx...
erm..like application download from market...can it move to sd card storage?
Firstly, you need the latest version of Android to move applications to the SD card (it won't work on stock/branded 2.1).
If you are running Android 2.2 and the applications you download support moving the app to SD card, then you can by going on settings->applications->manage applications. Then go to the application you want to move and then move to SD card.
