Help Need Help !!!
After the last update I can't delete bal,data,min,pmt from my contacts, Does anyone know how ?:confused::confused::confused:
I don't have the latest update, but are they saved under Google Contacts, Phone contacts or Sim Contacts? Just to make sure, you have gone into People, then select the name, hold the name on the prompt then select Delete Contact?
I never use them. I used to be able to delete them before the update. I used to be able to hold it down & delete it but now delete doesn't come up on the screen
