Help Need Help
tcb2185
Sorry im sure this is posted some here I just Upgrade to a Samsung Phone and want to wipe every thing out of my huawei ascend so i can give to to my Girl Friend. I try to go into setings and reset to factory defelts that way. The phone Locks up on huawei Screen.. The phone is Rooted. I also Try Pushing Vel Down,End Call and Power on. And it locks up at the Huawei screen again. Any Idea What i need to do here?
Any Help would be Great! This Old phone Has Been Well to me.. Not sure if its paying me back for upgrading to the samsung or what lol.:confused::confused:
Try using rom manager or anreboot to boot into recovery(both on the market).If that didn't work reflash your recovery assuming its clockwork should solve your problem. Plenty of tutorials on the forums look around.
Just tried both the apps above both do the same thig locks up at the white huawei screen I will try reflashing the recovery.
Also i used GingerBreak to Root it.
I just noticed, your doing the fastboot buttons... To get into recovery, it's volume up + send + power. But if you've flashed back to stock, you'll have to re-install CWM.
I downloaded Com Manager from the market and Reflashed the Recovery that way and tryed to boot into recovery with no Luck at all... Phone Still Locks up at huawei Screen. im sure im doing some thing wrong. do i have to add any files to the SD Card?
