Help Need help
s8nb8n
Ok i have been searching for 8 hours straight on this issue.
i uninstalled the stock browser and now my market dont work and i tried reinstalling it it says not installed, i tried sending it to system/app and chmod 644 and it still dont work. ive downloaded newer and older markets. Can someone help, and also if someone could post the apk and odex files from their stock lg connect
i think you need to do a factory reset if it will fix the missing file? i would do that or flash a rom to the phone and things like this. I think you know now not to remove system files and launchers. i was on a custom rom once and did not like the launcher i uninstalled the app and had a blank screen so i had to flash stock and basically start anew.
yea i did the hard reset using the power button and volume down keys, and i did it from privacy. there is no way to reinstall the rom on this phone because there isnt a stock or custom rom to download. or even clockwork mod for it :-( i wonder if i can make metro just give me another phone lol
ya the solution is to reflash...cant really do that on this phone yet. i had someone try pushing it and everything im open to any ideas.
