Help Need Help!!
Okay I am not sure what happened. Upgraded to ICS through Kies. Went fine. Got the Charging Paused Voltage Too High message. Was getting mad and wanted to revert back to Gingerbread. Read up on who to install firmware manually by using Odin. Downloaded Odin, downloaded 2.3.6 from sammobile. Loaded the firmware into Odin then booted phone into download mode. Connected USB flashed the firmware, said it passed. After the phone rebooted and was ready to go through setup wizard I get the message that said something about "framework google calender (process has stopped working etc)" and it also gave me a "framework google acore (process has stopped working etc) So...tried it again same thing. So I upgraded back to ICS again through Odin and now when it rebooted and it was going through setup I am getting pop up messages saying "Unfortunately, Movies has stopped." I hit okay, then I get this message "unfortunately process.com.android.phone has stopped", hit okay, then get "unfortunately calendar storage has stopped" After these message pop up a few times the phone then reboots itself. Does anyone have any idea what the hell my phone is doing?
I just want to get something loaded back on there so I can exchange it under warranty because I've having other issues with it. Sorry for the typos..Im tired and very angry right now. :)
well first off you have voided your warranty, now they may or may not notice if you do send it in. secondly, do a factory reset then odin back to stock, if you still get the force closes odin again
Awww dont tell me I voided my warranty...how did I end up doing that? Just by using Odin? I tried to do a factory reset on the phone by holding the volume up/down key and power button at the same time but the screen that appears is the press volume up if you want to load custom rom or vol down to restart phone.
Okay got ICS back on the phone through Odin. I was able to quickly get through the setup before phone rebooted and did a factory reset in the settings. Did I do something wrong when I tried to go back to stock firmware using Odin?? Should of worked right?
are you still having problems, your last response kind of confused me. but odin does void warranty, theres been discussion if samsung can even tell its been used or not though
