Root Need help?
oddtrey10
Ok, so here's what happened. I was using my phone (ascend, rooted, cm7) when the screen just kind of started dimming. Then it died (while it was on the charger.). Now, whenever I try to turn it on, nothing happens. When i plug it in to a charger, the 4 buttons flash. When I take out the battery while it's on the charger, it goes to the huweia(?) screen. Also, when I take it off of the charger and press the volume up, end, and power button, it shows a screen that says 'updating firmware step 1/2. Unpacking. Update failed.' Can anyone help?
reverting back to stock, ok power down the phone and download and extract this to your desktop MetroStockRecovery-SCRIPTS.zip after you done that press and hold vol down, end key and tap power, your phone should be on the white huawei screen and it should stay there plug your phone to the computer via usb cable, now open the folder that you extracted and run both of these file, first run fastboot-windows you will see a black box come and leave quick, next run metroPCSStock-windows.bat than another black box will pop up and it will do its thing, once it finishes the phone will automatic reboot itself.
You never stated which CM7 you were using... 729mhz? 748Mhz? Perhaps you have one of the lazy ascends....
