Root Need HELP!!!
bmc1793
Okay I downloaded the gingersteem extreme on my phone, and it seems to make my phone freeze like every second! and I want to know if there is anyway i can remove it from my phone:confused: i did a factory reset yesterday but i was just stuck in cwrm but i finally got it wo work again, good thing, but i just want to remove it and put my phone back to the way it was before i did all this junk, and it doesnt help that i'm an idiot when it comes to this :( So if anyone knows how and could tell me the steps i will be grateful!!!!!
The solution to your problem is to flash Rom #2.
Just out of curiosity.... what software version was on your phone before you flashed gingersteem? Because I'm affraid that if you were still on zvb or zvc.... you may still have the same issues if you flash number2 (built off zvd)
Let us know how your making out.
