tornredcarpet
Backstory: So I have a Motorola A855 Droid running FRG01B, and it freezes way too much.
I did a factory reset to clean kit up, but now it freezes to the point I can't even use it anymore. It freezes on the home screen and won't load anything else.
So I'm trying to flash it back to like 2.1 or 2.01 or 2.0 or anything.
I've factory reset my phone and connected it to my computer to USB 2.0 ports (I've tried all 3) and started up the phone in bootloader mode. The phone battery is fully charged (I even had another OEM battery swapped to check)
I am running Windows Vista 32-bit and have 32-bit motorola drivers installed.
The system has been since rebooted after installing them.
I am running RSD Lite 4.6 as an administrator (right click and run as)
I have 2.0, 2.01, and 2.1 roms sitting in my C:\ root folder, but I have been unable to find a good checksum to verify them with.
I have Device ID set to the First-Come-First-Serve radio.
It still doesn't show the phone. The start button is greyed out.
That's all I was able to pull from the forums. What else can I do?
FYI, if you have an answer for how to stop the freezing, that would be even better.
