Root Need Newest RUU NOW!!
So even with the update that is the only ruu to use. And the cause is my phone is stuck in boot loop whenever I flash or restore a rom
Ahh...You're using 4EXT?
Sometimes it doesn't work right...
Fastboot the kernel, and it should be fine after that.
Just out of curiosity how did you get hboot 1.58 (per your sig in the OP) if you are stock Virgin Mobile with S-ON? You should have hboot 1.57.
ramjet73
Here's what I would suggest. Fastboot your recovery using the following command from a PC:
fastboot boot recovery.img (where recovery.img is the name of the recovery you flashed)
That will put you into recovery in a mode that will allow you to flash the entire ROM, including the boot.img (kernel). If you are using 4EXT make sure SmartFlash (S-ON) is disabled in the tools menu, then "format all partitions except SD card" in the wipe/format menu and flash the ROM.
I've been S-OFF for a while but that method always worked for me when I was S-ON. However, if you want to run anything other than Sense based ICS ROM's you are going to have to get S-OFF and downgrade your bootloader (hboot).
ramjet73
ramjet73
i fixed using this method thank you
I download the file I see its not a zip file soo how do I installed
My hboot is 1.58 and s-off
How do I exactly install or flash the RUU
This just my 2 cents, but unless you are having a MAJOR problem or wanting to return phone. There isn't really a reason to run the RUU. It will put you back to stock ROM, S-ON, and 1.57 HBoot. Also before you run the RUU .exe file from your PC, I believe you have to re-lock the phone.
Ruu should NOT make you s-on
That's correct. If you are already S-OFF, flashing the RUU does not set you back to S-ON and you don't have to relock the bootloader before running it. The only way to set S-ON is via the "fastboot oem writesecureflag" command which should not be issued unless you are sure that you have a signed stock bootloader installed.
For S-OFF users, as long as a nandroid is done before the RUU is flashed, the only things that are required afterwards are to flash a custom bootloader and recovery, then restore the nandroid and you will lose no settings. I agree that if everything is running fine and you are S-OFF there is probably no need to flash the RUU, but if you are having problems the whole process including taking the OTA (if you can see it) shouldn't take more than an hour.
For S-ON users, I think it's a good way to make sure everything is fully stock and in sync before doing the wire trick, but many have done it successfully with custom ROM's and recoveries installed.
ramjet73
ramjet73
i need a ruu for hboot 1.58 htc evo v 4g like asap !!!
You and a lot of other people.
If you find one please let us know since AFAIK there aren't any available yet for the Evo V or Evo 3D March OTA's.
The best you can do at this point is to either flash the stock ROM or go for S-OFF if you don't have it already, then flash the original RUU and the two updates which should be close to the equivalent of a 2.95 (hboot 1.58) RUU.
ramjet73
ramjet73
Do we know that the ruu won't work or is it assumed? The November ota put the 3d on 1.58. Have we compared the sprint 1.58 to the vm 1.58? Did the ruu work on Sprint 1.58? Is firmware also scrutinized bytheruu prior to working?
There was no November OTA for the Evo 3D. The original Sprint ICS RUU from July came with the 1.58 bootloader and that's still the most current for the Evo 3D so S-ON users of that model that have taken the March OTA can still flash the RUU if they downgrade their main version (mainver).
The Sprint and VM versions of the 1.58 hboot are identical but that has nothing to do with why the RUU won't flash. The problem is that the Evo V RUU and November OTA have the 1.57 hboot and the March OTA has the 1.58 hboot and the RUU process won't downgrade the hboot for S-ON users.
ramjet73
ramjet73
I think I am starting to see what you're saying. So even IF we could run the Sprint RUU, that's going to put Sprint firmware on there, and the HBOOT will still be at 1.58. That would then probably affect how the OTAs were applied. Again, I said "if" above...
Doesn't seem like any workaround is feasible. But I wonder...S-ON prevents unsigned stuff from being applied. Isn't the RUU signed?
