need qwerty in landscape
dsergison
the abc def ghi 3-to-a-key layout drives me nuts. keyboards I try such as go keyboard just changes the look but not the layout.
they are only qwerty in portrait. can find no solution or even discussion online. what the heck? I cannot be the only one.
yeah, or at least it does auto rotate. why? when it rotates my portriat qwerty layout turns into a landscape 9 key multi letter per key.
always has.
open your keyboard as if you were typing a message. look above letters you should see arrows pointing left and right and this " >>" press this symbol several times to change keyboard layout
:D
that's it! (>>) key. so simple, any I could not find it in any settings menu. I was so frustrated. feeling a bit silly now.
Thanks so much.
