If you have just changed kernels, that is probably the issue, reboot back into recovery and flash a different kernel. If you don't have a different one you may have to flash the entire rom again.
Of course, if you did a nandroid backup, reboot into recovery and restore the backup.
i was rooted stock 2.2 and tried to get cyanogen5.0.8 i forgot to back up and did wipe now phone is stuck on motorola logo, but i can go into clockwork recovery
put a rom on sd card manually by removing sd card and putting into computer. Make sure you put it onto the root of the sd card. Not into a folder. Put the sd card back into phone. install via recovery.
found a rom in clockwork and now phone is working but its running on 2.1 and not froyo, and on cyanogen 5.0.8 and with no market whats a better rom and how do i get market back
