Root Need Root/Radio/Rom help
Klauven
Member
There really isn't a very good comprehensive guide to rooting/radios/roms. Some use CWR, some use only Odin. Some say ROMs have root, some say you need root first. It hard to get your mind wrapped around it all.
After reading numerous threads, here is my understanding.
Use Odin to flash ED01 (Guessing this is some ROM that can be exploited for root)
Use Gingersnap to root (guess this is a method like z4)
Use Odin to install CWR
Boot into CWR
Install ROM from CWR
This sounds like a pretty complex process, if anyone has something easier PLEASE share. I wish you could just flash a ROM with root using Odin and be done with it.
I come from the Moto droid, I tried just using Odin to install CWR with voodoo so I could install a ROM but that failed.
Also, whats the deal with all the EE4, EP1Q, EXT4 mumbo jumbo.
If you find the GummyCharged 1.9.1 ROM on XDA, it has an Odin package that will install everything at one time, just like you want. You'll have root, CWM, a voodoo capable kernel, and a badass ROM.
EE4 Was a leaked update that turned out to be the latest OTA. Its Froyo. EP1Q is the latest Gingerbread leak.
You can't use Gingersnap or Gingerbreak to root the Charge. You have to flash a rooted kernel or ROM.
Well, I did as you said and it worked like a charm. I really appreciate the advice. I just have 2 issues to work out now, 1. Setcpu says I can overclock to 1600mhz but even 1100 cause my phone to randomly reboot. 2. When connecting to my bluetooth speaker, it will pair but not connect.
