need rooting rar file for my phone model
Rap monz
i need help for my lava iris 500 to root..i've tried most of the apps(root file)from google play service its doesn't match with my phone/can't root,so where/how can i find that root file..
Welcome to our AndroidForums :).
I don't actually believe there are apps hosted on the Play Store that will root a device.
There are apps that will work on rooted devices, but I don't think Google allows "apps that root a device".
(hopefully you're not one of the myriad / many folks that tried using my root app and left a negative comment because it didn't root your device (despite the app clearly saying that it won't do so anyway :p)).
You're likely to only find apps-that-root on websites and not the Play Store.
Hope that helps.
