need serious help!
scottwvu
I downloaded imusic and proceeded to download some songs.........no problem there.
However, I can't seem to figure out how to delete unwanted songs from the SD card. How is this done? :confused:
And yes, I searched :D
i don't have the app, but if you can't do it from the phone, have you tried plugging into a computer and doing it that way?
Either suggestion will work. If you have a lot of stuff you need to delete it might be faster to connect the phone to your computer. fyi if you haven't done it before, you need to pull down the status bar, tap on the sd card, and tap on "mount" after you have the cable connected.
Astro will also work if you just need to delete a few files but could be cumbersome to delete a lot with it.
Just open iMusic and select the 'My Music' tab at the top , select 'Downloaded Songs' and then long press on the song and select delete.
