S
spezticle
Guest
I've been following the rooting guide.
I've downloaded and unzipped the GingerBreak, su, and Superuser.apk files and the android sdk. and i've pushed GingerBreak and su to /data/local/ without problem.
my problem comes into the part where i run
essentially, a little, but nothing happens.
I let it sit at that screen at 2am last night, woke up this morning around 10am, and nothing had changed. i've rebooted my phone and tried again a few times...
Any insight as to what could be wrong?
Code:
/data/local/GingerBreak
Code:
16:21:55 benjamin@blend27:~/root/abX_FILES$ adb devices
List of devices attached
16:22:01 benjamin@blend27:~/root/abX_FILES$ adb devices
1000064fac22 device
16:23:04 benjamin@blend27:~/root/abX_FILES$ adb push GingerBreak /data/local
157 KB/s (16830 bytes in 0.104s)
16:23:31 benjamin@blend27:~/root/abX_FILES$ adb push su /data/local/
248 KB/s (26336 bytes in 0.103s)
16:23:40 benjamin@blend27:~/root/abX_FILES$ adb shell
$ /data/local/GingerBreak
[**] Gingerbreak/Honeybomb -- android 2.[2,3], 3.0 softbreak
[**] (C) 2010-2011 The Android Exploid Crew. All rights reserved.
[**] Kudos to jenzi, the #brownpants-party, the Open Source folks,
[**] Zynamics for ARM skills and Onkel Budi
[**] donate to 7-4-3-C@web.de if you like
[**] Exploit may take a while!
[+] Detected Froyo!
[+] Found system: 0xafd1452d strcmp: 0xafd1d7ed
[+] Found PT_DYNAMIC of size 264 (33 entries)
[+] Found GOT: 0x000162e8
[+] Using device /devices/platform/s3c-sdhci.2/mmc_host/mmc2
[*] vold: 2386 GOT start: 0x000162e8 GOT end: 0x00016328
