sghere
Hello!
I guess I need some expert advice here. My Droid has become increasingly slower due to multiple ROM's I've installed. I noticed that when you uninstall an application, the directories and misc. files are left behind on the SD card.
Is there a way to format the SD card and phone then re-install everything, or do you have to leave certain directories/files in place?
Not sure if normal wear-n-tear is making the phone slow, if it's the new 2.1 release or what. I do have quite a few apps installed, but don't use all the time. I reboot the phone a few times a day (battery pull) and that helps...but just sitting there it will start lagging. When going in and out of a program, it could take 5-10 seconds before the home screen populates.
I'm not using any Live Wallpapers...just a plain black background. Nothing running and it constantly shows 50-60mb free in memory. I am running SetCPU overclocking it to 1Ghz...but that's it.
Any help would be greatly appreciated!
Shayne
Shayne
