A few days ago I bought an activated a used Evo to tide me over until the SGS2 comes out. I was hoping it would have froyo on it so I could root but no such luck. I had heard that there wasn't a root for gingerbread so I thought I was SOL.
But then I read somewhere that its possible for some phones to be downgraded if they had been rooted in the past or had an older version of Hboot. I searched for a way to check the Hboot version but the method of powering on the phone while holding down the Vol Down key is not working for me. It just turns out like it normally would even though I'm holding down the Vol Down button the whole time.
Here are the current numbers in the software info section
Android
2.33
Baseband
2.15.00.05.02
Kernel
2.6.35.10-g4e39384
Build
4.22.651.2 CL60865 release-keys
Software
4.22.651.2
PRI
2.15_003
Additionally this morning the phone came up with the following message:
"A system upgrade for 2.3 (Gingerbread) is available that provides minor enhancements. Please download and install the following update. System Upgrade 4.24.651.1 (6.07MG)
-FOTA Update"
I declined the update.
If someone could provide me with some guidance that would be great. I've been trying to find another way of determining my Hboot version for the past hour with no luck. I have a feeling I can't root and should just take the above update to fix some bugs, but I want to be sure.
Android
2.33
Baseband
2.15.00.05.02
Kernel
2.6.35.10-g4e39384
Build
Software
4.22.651.2
PRI
2.15_003
-FOTA Update"
