Hello all!
I was wondering if I could have a little help from somebody that has rooted their LG Shine Plus and is comfortable with a rootexplorer app.
Basically my situation is that I was born without a brain, and removed an embedded app. I used titanium backup before doing so, and discovered to my dismay that backing up an embedded app doesn't work so well, so I was only able to backup the app's data, and not the actual .apk file. None of my other backups/Rom backups have this app in it, so I was wondering if someone could lend a hand.
The app is the Nuance Voice Control software that comes with most of these phones. I was wondering if someone could use a rootexplorer, and navigate to Root\sys\app (where i believe the embedded apps are stored), and simply copy the .apk file associated with nuance voice control to a safe place, and send me or upload the copy. This is a very safe procedure, as you are not altering any of these files, but simply making a copy and pasting it somewhere else. I have done this with all my important embedded apps (after i learned from my mistake with nuance) which i know are rare and have heard that some factory resets could make disappear (eg. FMradio etc.).
Only trouble is that I don't know exaclty what the associated .apk file is called, but it should have the same name as the program (or ~com.nuance.android...).
Anywho, I realize it's a long-shot, but I just want to say thanks to anyone willing to take the time and help me. I can't offer much more than good karma and 3 magic wishes, but you can bet I and others will be here to help anyone with similar problems-- after all, that's what a power-user community is all about!
Again, thanks all!
Again, thanks all!
