Root Need Some Help with Uninstalling Bloatware (UPDATE)
So, using Root Explorer after having rooted my Admire, I went ahead and started deleting bloatware I knew was already safe to delete. Suddenly, though, after having deleted one of the apps, I keep having this exact message pop-up constantly:
"Sorry!
The application com.nuance.nmc.sihome (process com.nuance.nmc.sihome) has stopped unexpectedly. Please try again."
What is the application, and what did I get rid of that I shouldn't have or this app needs to work?
Thanks in advance.
EDIT (11/4/11): Well, that problem is solved, but I did accidentally uninstall downloadprovider.apk and downloadproviderUI.apk, so now the Market is not usable. Can't seem to find a manner to re-install it, however. Can anyone help with this?
EDIT 2: Solved the issue. Just a bit of file copying and changing permissions solved the issue I had with the Market.
be careful un installing apps you are unsure of, i have done it alot just to see what happens, but i always break stuff to fix it tho...lol
