Need some help!
Okay, how do you delete the widgets/shortcuts on the seven home screens. I accidentally put something on the same home screen twice and want to delete one of them. And how do you order them how you want them to be?
Then, how do I sync my iTunes library to the phone?
Just press and hold the widget/shortcut the one you want to remove, then you could notice "Remove" bin appears in the bottom of the screen. Now you need to drag the widget and place it on top of Remove bin. Once RED color appears around the Remove bin then leave the widget. The same way you can move around the widgets.
To delete widgets or short cuts just press and hold them and drag to bottom of screen to where it says delete, to move them about press and hold and drag them to an empty space on your screen.
