Help need some help
rpsilva95
I have had my fascinate since last june. love the phone had a blackberry before so glad i made the jump.. the only thing is it is running sluggish and has been freezing alot.. just wondering if I should try to do a wipe and start over again to free some stuff up.. I am running gingerbread
Sounds like you need to clear your cache. My recommendation is to use an app on the market, like Cache Cleaner NG. You can set it up on a schedule to clear your cache, so you can keep your phone running quick as it did out of the box!
