Root Need some help!
rlind1
My problem is not terrible but inconvenient... I just installed bamf forever 1.10 and after i flashed the rom i updated my radios. I first installed the CDMA: 1.48.00.0906 and after this everything was still ok, after I installed the LTE: 0.01.78.0906. After I rebooted after flashing this my wifi was not working. It will recognize that there is a signal but it will not connect. I have tried manually turning my wifi on and off but it will continue to give me the message "unable to scan for networks" I have looked around and not seen any solutions i am sure there is one somewhere out there. I am hoping that there is an easy fix! Any help would be appreciated!
Thank you!
Thank you!
wifi errors are typically from a mismatch in the wifi module and kernel. you can try installing your radios as a single download instead of seperately. if that doesnt help,boot to recovery and wipe cache and dalvik,then reflash your rom to reinstall the kernel. it should work after that :)
http://androidforums.com/thunderbol...adios-recoveries-hboot-updated-1-25-12-a.html
