enduser2941
Member
Hey guys! I have a question, I am hoping you can give me some little trick or suggestion here. I have a Samsung Galaxy Note with ICS4.0.4. It has a ton of apps installed on it, however I thought it has\d plenty of memory.. My problem is the device has been running VERY sluggishly. Like if I am in SMS mode and I am typing, the device can not keep up with how fast my fingers are typing. There seems to be quite a delay between when my finger hits the letter, and I hear and see the letter appear.
I have an 8GB MicroSD card 2GB used. On Board, using Easy Task Killer it says I have used 596MB of 720MB ..well I am not sure..cause that seems very low. I thought this thing had eithe 8GB or 16GM internal memory, so I am not sure.
EDIT: According to specs..
RAM: 1,024 MB
Internal Storage: 16,384 MB
Maximum Removable Storage: 32 GB Removable Storage Included: 8 GB <--Thats what I have
Removable Storage Type: microSD
For performance apps I have App Cache Cleaner and Fast Reboot. Though even after running them, I see no improvement in the sluggishness. The only time there seems to me any improvement is if I completely reboot the device but it seems to be lost pretty quick. Can you please PLEASE help me out here? I really need someway to improve the performance on this thing. This thing should be zippin and instead it seems to act better as a paper weight then the technological wonder it's supposed to be.
I am not outside of purchasing some app to help with the performance if you guys can guarantee me that it will help. I have tried a bunch of the freebee apps such as what I stated above and they work, usually, but for some reason, they just don't seem to be helping anymore and I am not sure at this point what to do.
Thanks guys! I really appreciated it!
RAM: 1,024 MB
