Need some serious help - Cannot install any application
axydas
I own a Cortex A8 APAD IMX515 with Android 2.2 Flash 10.1 800MHz and 512MB RAM. I am having problems installing or updating apps from the market or from any other source. As I go to install applications or updates, everything appears to download just fine but it then stalls on the installation.
Moreover, under Application Management, application and data never resolve - it keeps saying "computing..." same with the Cache it also says "computing..."
I do factory reset but still i have the same problems. Is anyone else having this problem? If so is there a fix for this? I found somewhere that i have to format the internal SD card. Is this the solution? If yes how to do it?
Please note that i am new with Android operating systems so please if you have the solution, send me all the details.
Really thanks!!!
