Root need someone to help root lg motion. rooting newbie here
I tried once before to root my lg motion. I found what i believed was a good solid guide however during the last (maybe one of the last stages) stage it didn't go thru.
The part where you open command prompt and type the "c:/o4xr" or.whatever.it.is
Basically can someone provide a fail proof guide (step by step with clear directions) to.root the lg motion?
Im pretty new to android (less than a yr user) so please dont skip any minor details.
Last time it failed my camera stopped working and all my pics were there but they were all blacked out
A factory reset solved my issue (thank god) id like to retry but dont want to risk a hard brick.
Thanks in advance!
I'm not really familiar with this device but I moved it to the root section so that you can get the best help. :)
Thanks in advance!
sometimes it will fail. you just got to do it again until it works. note: it won't work if you have another phone plugged in or if your using bluestacks or other android emulator they can cause conflicts also.
also i think you have to use usb 2.0 port and not usb 3.0 port i could be wrong though
