dan44762000
i have cyanogen 7.2.0 running on my phone and i like it a lot .
all i needed to do was boot into recovery mode and install the zip file i put on the root of my sd card (32gb) and all is fine .
however i now want to make a partition and get extra valuable internal storgae as i am down to 32mb after clearing the cache on all apps .
have moved everything i can too the sd card but still only 32 mb .
even cleared the dvalrik cache with titanium pro .
so what i need is a step by step guide for creating a partition and then using something like s2e or any reccomended app to move the lot over .
last time i done it i messed up big time and lost acess too all apps and my phone wouldnt even boot but i just , went into recovery mode mounted my sd card put the cyanogen mod zip file on there unmounted and installed and bang everything working fine .
so is there a noob guide to going through the steps to create the partition ?
also i am assuming i need to completely wipe the phone off everything ?
thanks dan
thanks dan
