No way to enable usb debugging with a dead screen.Ok so how do i put phone into debug mode with a broken screen. I'm looking for blind step by step such as: Hold power button and volume down
hit down 2 times
etc.
The screen is broken, he can't see those stepsHi outtaluck, What you want to do is get into Developer Mode. Settings > More > About Device > Tap Build number 7 times which will put phone into Developer mode. > Tap Return Arrow (top left of screen) > now you should see Developer Options between Date and Time and About Device. Open Developer Options and scroll down to USB Debugging and check. This should be done when phone is connected to your comp. When you're finished you need to go back and uncheck USB Debugging. Hope that's what you wanted.
