junkie2100
Android Expert
i should be getting a test unit but it will need the stock rom before i can use it. can someone do a nandroid or something and get it to me?
If you will post a step by step how to do it I will be glad to. Never worked with adb before.also it may very well need to be rooted for it to work yes. but recovery will never do it
You need custom recovery for that to work.well, first we could try the nandroid online backup tool
Here you go. If you need other files let me know.ok well i should be getting the device today, just gotta wait on the stock rom system.ext4.tar... then i can work on cwm
https://www.dropbox.com/s/3unl7hq2mhaubr2/system.ext4.tar
