i get no services so i cant call, text or receive anything it does boot though what else you need to know
i have signal ..wifi works internet works with wifi..bluetooth works... but no service
. Try also the wifi tether hotspot option under settings to see how it goes. It won't connect most likely without the apn though. Just want to make sure I have it setup right for ap/softap.sd mount works.... tethering gives me an error
Anyway, are both Trident and getitnowmarketing working on two separate projects or is this a joint effort?
If you guys need any testing let me know. I recovered my optimus from near brick state with custom recovery and the zero rom 1.1. I also have active service, and in case i did brick my phone I can war swap it easily (cause I work for metro).
