Root Need The ROOT Pro's... Please help...
Cleaner
Was running CM7 RC4. Went to download the newest nightly. Downloaded, installed fine. Added the newest incredikernel, which was operating fine with RC4. Rebooted fine... Went to add the GB Circle Battery, and now I'm stuck in a boot loop.
Can't restore any of my backups. It does fine until the end and says, "skipping sd-ext"
Anyone..???
Sure... If I tried to restore a backup through recovery, it would end by giving me the message I posted above. I had to restore .zip from sd card, go into the clockwork file, and restore from there.
I tried to install the Cirlce Battery again, with the same results. It must have some conflict with Nightly #36.
Works fine on RC4, and the previous Nightlies.
