Not that I know of.
But the bigger question is, will they be okay with you having a cameraphone that's disabled? Will they even believe it's disabled?
Can you see where this plan fails? You can't get away with a now-you-see-me-now-you-don't solution, it's gotta be a permanent thing.camera phones are verboten at work [but I want to be able to] disable and re-enable when I want
Sticking masking tape over the lens, or any such (easily) reversible procedure, probably won't cut it.Use any ICS mobile to disable the camera app. U can Disable/Enable the any app in the ICS. The option is developed. I am very Thankfull to Google for this.Does anyone know of any apps that can disable the camera? My work does not allow camera phones.
