need to install a flash player
  • Start date Start date
A
Android Question
Guest
I have a galaxy 3 10.1 and want to install a flash player for my games
To my knowledge development for flash was stopped for ICS and above. You might be able to find a thread that has an older version of flash and try to install it but my own attempts at that have always failed.
See this thread for information about how to get the Flash Player for your device:
http://androidforums.com/solved/771002-flash-player-android-phone.html
Here's the quote of the relevant post:
Brian706 said:
Adobe officially stopped supporting mobile flash awhile back. You can find all of the archived flash player versions at the adobe website here: Archived Flash Player versions
Download the .apk file from adobe, if you're on Ice Cream Sandwich or JellyBean you will probably want to get the latest version available. Put the file on your phone (sd card or internal storage).
Use a file manager to browse to the file and tap on it. Choose install. That should be it.
If you haven't already, you will probably need to go into your settings: settings>applications>unknown sources
Check the unknown sources box. It allows you to install apps that aren't on the Play Store.
Cheers!
