Root Need to send phone back, how to revert?
How do i revert to non-rooted so i wont have any problems when i return the phone to verizon?
just flash the sbf file. if you have 2.2ota, then use the 2.2 full sbf. if you never got 2.2 ota, then use the 2.1 sbf. go to the rootzwiki site for the files and instructions
I have TiBackup. So I'll just backup my apps to my SD card, then put the old SD card in the new phone, then just restore my apps?
So if your rooted with the 2.2 OTA. Do you first have to unroot it inorder to do the 2.2 full sbf flash. I ask because I'm having trouble setting setcpu it not recognizing the app as an SU app and I have tried everything other than fully flashing phone.
nope.
