You can still activate it through the website.
The activator app is just a link to a portion of the website, as long as you removed the phone from your account, they can either activate it from the website the old fashion way, or flash a froyo rom.
Were going to backup the ROM on there now, and then bring that phone back to stock. Should take about 20min from start to finish. Just be sure to have a microSD card for this
1. Download the Harmonia ROM (Link is at the bottom) and place in microSD card
2. Go into the recovery (option appears when you try to shut the cellphone off)
3. Select the backup option in the "Backup and Restore" section.
4. Then you wipe cache partition, dalvik cache(advanced section), and data/factory reset.
5. Go to mounts and storage section and format boot,cache,data,and system.
6. Go to install zip from sd card. Navigate to where the Harmonia zip is at and select it.
When you get your phone activated just go back into your recovery and wipe and format the same things. Then go to the backup and restore option. Select restore. Choose the date stamp for the backup you made.
If for whatever reason you don't feel like doing this, feel free to send it back to me, and I will do all of this for you, and even activate it for you.
[ROM] Harmonia 1.85 Froyo (Aphrodite+Picasticks) 10June12 - Android Forums at AndroidCentral.com
