A
Android Question
Guest
my phone rooted now its a brick how do i fix
Does you get a soft brick or hard brick? It's easier to fix a soft brick.
Please describe your situation in detail, does it can boot into the system? Or stuck at the bootloop? Please clarify.
How do you flash stock ROM?In order to fix things back you need to flash the stock ROM over to your device again !
Well, flashing process is different for every device ! Like if you have a samsung device then you use ODIN to flash the stock ROM over to your device and in case of HTC its different ! Do one thing let me know which device you are trying to flash stock ROM onto, I'll guide you with the flashing !![]()
1. Download the needed stock ROM to your SD card
2. Enter the Recovery mode (Different phone have different method, normally you can try to hold the volume down and power button to restart)
3. Select install ROM from SD card and select the ROM you downloaded
4. Wait it process and finish
I cannot drag the .zip file to the sd card. an error pops up saying that my device doesnt support this file. Any help?Hi, where can I find the stock ROM for my phone (zte Overture) I googled it but haven't come up with anything. If you have any idea of where to find it, will you please help me?![]()
