Help need unrooting help
i rooted my lg connect 4g now im try to take off
it with the all in one but it keeps tell me the system cant find the path specified i already done a factory reset but it didnt take superuser off can somebody please help,
android version 2.3.6
sw version ms840zva
hw version rev.1.0:confused::confused::confused::confused::confused:
sw version ms840zva
are you running the script from inside the zip file? make sure you extract it first.
