Root Need urgent help
whtge8
I tried to install the vanilla lock screen but that sent my phone into a boot loop. I wiped the data, cache, and dalvik, reflashed the rom and now its stuck on the 'htc EVO 4G' screen. Tried this about 3 times with the same results.
Edit: Nevermind, all is good. Still no vanilla lock screen though. Not going through that scare again. Anyone know what I did wrong? I downloaded the .zip from fresh's site that removes htc's lock screen and world clock, I flashed it and got stuck in boot loop.
If you manually remove htclockscreen.apk, the default lock screen will revert to vanilla. What ROM are you running?
