Root **Needs Help**
malemodel
i downloaded the theme zvd goldensteem and now my phone(lg esteem) starts up but force closes everytime after start up. i have rooted my phone and backed up the data but the theme comes on with the force close what can i do to save my phone and the theme
i will tell you what i have downloaded: plague_extreme.zip, plague overclock kernal(set at 1.5), the root and (zvd)goldensteem#2.zip theme. it force closes on start up it comes on and then forces closes continuously and i cant go past the force close
i dont completely know what ROM im running. on the force close it says the application status bar(process com.android.systemui) has stopped unexpectedly Please try again and the other force close menu says the application Sony Ericsson Home (process com.sonyericsson.home) has stopped uexpectedly. please try again the second force close keeps poppin up
Use android commander to reboot into recovery and restore your backup. Youcan also use the power + volume Up /down method. Android commander is much simpler though. Us
Welcome to Android Forums malemodel:D
Or just hold down the power button and both volume keys simultaneously-when it shows the option to erase all data press the power button to select.
You should now boot into CWM and be able to restore your backup that you made.
Going to move this to the root side-just an FYI
Plague extreme is for ZVB
Goldensteem is for ZVD
That's your problem right there.
Either upgrade to ZVD or use a theme for ZVB.
Boot into CWM to restore your backup. Power button plus both vol up vol down. Power through reset menu.
Been working on the Green ICS theme. All I see is 20 windows open on my PC. AINT GOT TIME FOR NO DOG GONE LINKS. lol
Good job Big. I solve the problems, you link em up. Dynamic duo. lol
I didn't realize man-I'm sorry-here
xxoo
images
Fyi I ported Golden esteem for ZVB from KaneOfMars. So there is one for zvb
Well hell. Sounded good when I posted it.
Im just gonna go back and stare at GREEN for 4 more hours.
(Cartman voice) Screw you guys, Im going home. :D
