Root Netflix 1.7
camp8615
Long time reader, first time to post. I have recently updated to 2.2.2 on my lg optimus m. I'm running cm7.2.0 Bobz rom. My problem is with netflix. I believe recently they updated their app up to version 1.7. I used to run xda dblfster app for netflix version 1.2.2 that would not force update and also keep audio and video synced. For some reason now dblfster version are not working anymore its asking to update if you cancel the update it and try to play a show or movie, it tells you that the content is unavailable right now.
If you run netflix 1.7 it plays the shows but the video and audio are out of sync.
Is anyone else having this problem?
I attempted to try to test to see if same out come would come out on Kelsomods rom ezrider and it did.. I first tried dblfster 1.2.2 netflix version without update notification and just like on cm7 when running the app it asked me to update and if wanting to watch a movie or video it said it wasnt available to stream. I then tried netflix current version 1.7 and i was able to try to watch a movie/show and got video/audio sync problems.
i remember i used to not get any problems w/ dblfster version until recently
still trying to figure this out
I am having the same problems on my rooted Xoom tablet...it seems to fix if i turn off the memory optimizer and change my CPU governor to ondemand and mess with the min/max speeds a little.
I MISS MY XOOM!!! :( are you running ICS on it?! sorry to get off topic!? lol
Similar problems on a Coby Kyros 1126 running Android 2.3.3 If I run Netflix 1.7 I see a terrible audio sync problem. (Problem seems minor on my Kyros 8125, though.) Have similar problems with Netflix 1.6 Running Netflix 1.5.2 fixes the audio sync problem, however if I pause and restart I see a black screen if I rewind. Also, with the HDMI out connected to an external monitor, the tablet LCD display 'rips' and distorts.
No problem with Netflix 1.7 on my Acer Iconia A500 running Android 3.2.1 I suspect the problems relate to Android 2.3 (and 2.2 as well) to the Kyros or both.
