Help Netflix not working on 2nd gen Nexus 7 - help?
I just bought a 2nd gen Nexus 7 today and Netflix is not working on it. I downloaded all the updates to the Nexus and it's running build JWR66N. Tried re-setting tablet and uninstalling and reinstalling Netflix - didn't work.
Anyone else have this issue? How did you fix it?
Based on the build number you provided, it appears that either it's a first generation Nexus 7, or the software is really screwed up on it. New Nexus 7 tablets should be running a build that begins with JSS15* (wifi) or is JLS36C (data enabled).
Based on the build number I'm going to move this to the 1st generation. If it is later discovered that is a second generation, I or another staff member might move it again.
This IS the 2nd gen - I owned the first gen before this one. 2013 Nexus 7, 16 GB. It is saying software is up-to-date - I installed updates when I set it up and now it says it is up -to-date.
I did a factory re-set again and this time it actually installed to the updates, so now I'm running the JSS build. Netflix works now :)
That's good. I had a feeling that if it was second generation, that that software build on it was the cause of the issue. :)
Since it was a 2nd generation, I've moved it to its rightful home in the Nexus 7 (2013) forum.
