JDubbleTrouble
Phandroid reprted today that the epic was added to the list of devices supported by netflix finally but everytime i log in the app instantly closes anybody else gettin this or getting it to work
I got a Connection Error and now I'm getting Force Closes. What can I do to fix this?
I downloaded the Netflix App on Sprint's painfully slow 3G.
This is working for people over at XDA to force the update from 1.2.xxx to 1.3, which should cure up the FC's and Errors...
1. Go to Market and install Netflix
2. Reboot phone.
3. Open Market again and update the app
That worked perfectly. Thank you.
Doesn't look like Netflix will play on my 3G. I'll have to be connected to wifi to stream.![]()
Is the Netflix app ok to move to the SD card?
